02-21-2003 07:47 AM - edited 03-09-2019 02:12 AM
Does anyone know the 'Default timeout' for VPN5000? I would like to extended this if possible.
Thank you!
Mike
02-21-2003 10:10 AM
hi there
if we're talking about the VPN Group configuration the default is zero (no timeout). the range is 1-65535 before ending the tunnel session. Keep-alive packets and ICMP (ping) traffic do not affect this timeout. This prevents users from using ping to keep their tunnels up.
If TFTP, timeout = 40 seconds default (found in the device, database,options,tftp,etc).
hope that helps
02-21-2003 10:52 AM
Thanks a lot.
