09-17-2018 11:11 AM - edited 03-10-2019 01:05 AM
Is there a description of the types of messages included in each of the logging levels (0-7)?
Specifically, I'd like to know the difference between 4,5,6 (info, notifications, warnings)
Thanks.
Solved! Go to Solution.
09-18-2018 12:09 AM
you can refer standard RFC
https://www.ietf.org/rfc/rfc3164.txt
09-17-2018 01:04 PM
here is the good document,
https://www.cisco.com/c/en/us/td/docs/routers/access/wireless/software/guide/SysMsgLogging.html
From my notes as below :
Logging Messages
Parameter |
Level |
Syslog Description |
Description |
emergencies |
0 |
LOG_EMERG |
The system is unusable. |
alerts |
1 |
LOG_ALERT |
Immediate action is required on your part. |
critical |
2 |
LOG_CRIT |
A critical condition exists on the router. |
errors |
3 |
LOG_ERR |
An error condition exists on the router. |
warnings |
4 |
LOG_WARNING |
A warning condition exists on the router. |
notifications |
5 |
LOG_NOTICE |
A normal but significant event occurred on the router. |
informational |
6 |
LOG_INFO |
An informational event occurred on the router. |
debugging |
7 |
LOG_DEBUG |
This is output from debug commands. |
09-17-2018 02:22 PM
Thank you.
I was hoping for more specific information.
What types of messages are 'Informational'
What types of messages are 'Notifications'
What types of messages are 'Warnings'.
Is there a list or RFC which identifies what messages qualify as information v notification v warning, etc?
09-18-2018 12:09 AM
