11-29-2005 12:01 PM - edited 03-09-2019 01:11 PM
Hi, I upgraded the Pix 506e from 6.3(4) to 6.3(5). It then failed
to allow external port 443 traffic to our internal web server.
Error message on PIX when users try to connect is '710005: TCP request
discarded from (External IP address)/50649 to outside:200.x.x.x/https'.
I only want to allow external traffic through on port 443 to our Web server. No traffic is allowed out from internal hosts.
Pix config as below:
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxx encrypted
passwd xxxxxxxxx encrypted
hostname Pix
domain-name Pix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl1 permit tcp any host 200.x.x.x eq https log 7 interval 600
pager lines 22
logging on
logging console debugging
mtu outside 1500
mtu inside 1500
ip address outside 200.x.x.x 255.x.x.x
ip address inside 192.168.x.x 255.x.x.x
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
static (inside,outside) tcp 200.x.x.x https 192.168.x.x https netmask
255.255.255.255 0 0
access-group acl1 in interface outside
route outside 0.0.0.0 0.0.0.0 200.x.x.x 1
route inside 192.168.x.x 255.x.x.x 192.168.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
Any ideas anyone?
Thanks.
11-29-2005 12:58 PM
Config looks good, have done a < clear xlate> ?
sincerely
Patrick
11-29-2005 02:40 PM
Yes I have, also ran 'clear arp' for good measure.
