URL Filtering Questions
support
As possible Microsoft ISA server replacement next year, I would like to move URL filtering to the ASA systems if possible. Can anyone tell if using the ASA for this is a good alternative?
Here is what I would like.
1.) The ability to block certain URLs from being accessing by employees.
2.) The ability to track and report of employee Internet usage.
suschoud
asa works in conjunction with websense or smartfilter for url filtering.
all http/https/ftp etc reqeusts are redirected to these servers wherein url filtering rules are applied.
if u do not have these boxes,u can also use inbulit asa's capability to use regex ( regular expression ) to block urls.
For ex. , blocking myspace :
RUNNING CONFIGURATION (SNIPPET):
ciscoasa(config)# sh run
: Saved
ASA Version 7.2(2)
hostname ciscoasa
regex block-website ".\myspace.\com"
class-map type regex match-any cm-block-website
match regex block-website
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map type inspect http pm-block-website
parameters
match request header host regex class cm-block-website
drop-connection log
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
LOGS OBTAINED:
%ASA-5-415008: HTTP - matched request header host regex class
cm-block-website in policy-map pm-block-website, header matched - Dropping
connection from Inside:77.66.55.2/1958 to outside: 216.178.39.74/80
%ASA-6-302014: Teardown TCP connection 2036 for outside:216.178.39.74/80 to
inside:77.66.55.2/1958 duration 0:00:00 bytes 0 Flow closed by inspection
Here is a link that explains how to use MPF:
-- Using Modular Policy Framework:
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/mpc.h
tml
asa has limited capabilities to track internet usage.u can use some 3rd party tool for that.
hTh
Sushil
TAC
Thanks for your reply! That was very helpful information. Do you know what 3rd party tools are out there for tracking usage? We would want to track based on network userid.
Commercial products that creates graphs and analyzes Syslog to generate stats could be:
- FireGen http://www.eventid.net/firegen/
- Try this one FWLOGSUM (Freeware).
http://www.ginini.com/software/fwlogsum/
http://www.ginini.com/software/fwlogsum/converters/
It uses basicly PERL scripts and supports a wide range of Firewalls. You just need to install Perl in your Windows environment.
- Try Sawmill (Eval version)
http://www.sawmill.net/
- EIQ Networks Network Security Analyzer eiqnetworks.com
Hope that gives you some ideas what to try.
