08-04-2009 07:34 AM - edited 03-09-2019 10:29 PM
Hi All
Is it possible to add the secondary firewall also into the CSM using the standby IP, if firewalls are configured in active/standby failover
Solved! Go to Solution.
08-04-2009 10:36 AM
you should never need to.
csm should only manage active unit.
changes are not replicated from standby to active.
what is the point of keeping different configs in both boxes.
hTh
Sushil
08-04-2009 10:36 AM
hTh
Sushil
