Using 'Alias' vs 'Outside NAT'?
rsinghnyc
Greetings,
I recently started with a company that has a PIX 515. I upgraded the IOS from 6.1(1)to 6.3(5), and installed PDM 3.04.
When I try to run the PIX via PDM, it prompts with "PDM does not support the 'Alias' Command in your configuration..You should migrate to the newer "Outside NAT" feature (aka Bi-Directional NAT).
Here are my statements regarding 'Alias'. Can anyone please provide insight/examples on how to migrate these statements?
alias (inside) x.x.x.x y.y.y.y 255.255.255.255
alias (dmz) x.x.x.x y.y.y.y 255.255.255.255
static (inside,outside) tcp x.x.x.x www y.y.y.y www netmask 255.255.255.255 0 0
static (inside,outside) tcp x.x.x.x citrix-ica y.y.y.y citrix-ica netmask 255.255.255.255 0 0
static (dmz,outside) tcp x.x.x.x https y.y.y.y https netmask 255.255.255.255 0 0
static (dmz,outside) tcp x.x.x.x ftp y.y.y.y ftp netmask 255.255.255.255 0 0
static (inside,outside) tcp x.x.x.x smtp y.y.y.y smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp x.x.x.x 81 y.y.y.y netmask 255.255.255.255 0 0
static (inside,dmz) x.x.x.x y.y.y.y netmask 255.255.255.0 0 0
static (inside,outside) x.x.x.x y.y.y.y netmask 255.255.255.255 0 0
Fernando_Meza
Level 7
Level 7
Hi .. Alias command is used for translation of IPs that overlap .. for example if you have a remote site using 192.168.0.1 and you also have your internal LAN using the same range, then you could make 192.168.0.1 appear to your LAN as a different IP address .. in this case 10.10.10.10
alias (inside) 10.10.10.10 192.168.0.1 255.255.255.255
You could also use Alias to redirect traffic to a different address. This translates the destination IP.
In your config it seems like
they have been already configured by using
An so .. I suggest you to remove them .. then type in clear xlate ( this will interrupt your current connections for a few seconds ) .. and then test to make sure everything is OK and finally save the changes wr mem.
I hope it helps .. please rate it if it does !!! ..
Fernando_Meza
Level 7
Level 7
