VAC & AES
I know the VAC (not the VAC+) will handle 3DES encryption, but will it handle AES also? I'm aware that the VAC+ will handle both 3DES & AES, but I want to know if the VAC will handle both as well.
Jeff
j.contreras
Hola
No, VAC is only DES, 3DES. If you enable AES, it will be done by software (with pretty decent speed, but take care...)
