11-21-2003 07:16 AM - edited 03-09-2019 05:37 AM
I know the VAC (not the VAC+) will handle 3DES encryption, but will it handle AES also? I'm aware that the VAC+ will handle both 3DES & AES, but I want to know if the VAC will handle both as well.
Jeff
11-24-2003 09:59 AM
Hola
No, VAC is only DES, 3DES. If you enable AES, it will be done by software (with pretty decent speed, but take care...)
Log in to Community
