06-15-2004 03:30 AM - edited 03-09-2019 07:45 AM
I've got IDS 4235 running software ver 4.1(4)S97 installed in my network.
Yesterday I installed VMS 2.2 basic (including CSCsa16682 and CSCee60913 patches).
I upgraded the IDS MC Server to the 4.1(4)S97 and added my IDS sensor successfully.
BUT when I try to change my sensor configuration using IDS MC, I'm in troubles:
1) Trying to configure filters I'm receiving "Problem with File /WEB-INF/screens/filters.jsp!!!Exception thrown by getter for property destText of bean listentry" error message and no filters are shown.
2) When I modify one signature, the change is accepted. But trying to generate a config file I'm receiving an error:
"Generate failed. There are errors in the configuration of the Blocking Devices: (No destination addresses were provided.).
These errors must be corrected before you can deploy the configuration for Sensor.......
3) I don't see any configuration file in the configuration History.
has anybody succeeded in adding a running IDS into a new VMS?
Milan
06-15-2004 07:47 AM
I ran into the same issue (#1). This problem is covered by bug CSCin32177. Essentially, it is caused by the IDS MC not being able to import sensor filters if you are using system variables (i.e. $IN, $OUT, $USER-ADDRS, etc).
Supposedly the fix is slated for the next version of VMS. Hope that helps.
Don
06-15-2004 10:39 PM
Thanks Don.
Unfortunately the bug has Postponed status which means Cisco guys don't care about it.
I'm gonna open a TAC case to increase the bug priority.
Milan
