vpnclient.ini proxy settings ( how to, what does it do ? )
jpersyn
[main]
IsNoTrayIcon=0
[CertEnrollment]
NetworkProxy=10.1.1.42:80
This is the configuration of the vpnclient.ini.
But when I try to browse the internet via the VPN tunnel I got no result at all, is the prosysetting being used or not ?
What does this setting exactely do ?
awaheed
The option for NetworkProxy= does the following:
" Identifies a proxy server you can use to route HTTP traffic. Using a network proxy can help prevent intrusions into your private network "
If its not working in your case, open up a TAC case and let them troubleshoot this with you and possibly work with the development team to fix it.
Aamir
Erm,
Is the syntax I'm using correct for starters ?
I'm currently having some minor problems opening a TAC case.
