1. Configure the basic parameters to define a group which will be used to connect to the concentrator.
2. Enable Citrix Metaframe access for that group under WebVPN.
3. Obtain an SSL certificate for the public interface to facilitate Web VPN users to connect.
Note: If the Citrix Java Web Client is to be used, JVM version 1.4.2_06 or later must be installed on the client workstation. In addition, the root certificate must also be installed in the JVM root certificate store. All other ICA clients only require that the
root certificate be installed in the browser.
4. Access Citrix-enabled terminal service resources through a clientless WebVPN session.
