09-03-2002 02:31 AM - edited 03-09-2019 12:09 AM
I have pix 501 (Cisco PIX Firewall Version 6.1(1)) configured for VPN using MS certificates and I have vpn client 3.5.2 During ISAKMP negotiotion vpn client offers some options. For example:
ISAKMP: encryption 3DES-CBC
ISAKMP: hash SHA
ISAKMP: unknown DH group 5
ISAKMP: extended auth RSA sig
ISAKMP: life type in seconds
But pix does NOT see the right option. However when configured with pre-shared keys everything works fine. Below is log and part of pix config.
Config:
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dymap 10 set transform-set myset
crypto map mymap 10 ipsec-isakmp dynamic dymap
crypto map mymap client configuration address initiate
crypto map mymap client authentication mailserver
crypto map mymap interface outside
isakmp enable outside
isakmp policy 10 authentication rsa-sig
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3 address-pool ippool
vpngroup vpn3 dns-server 192.168.1.5
vpngroup vpn3 default-domain generaldata.ru
vpngroup vpn3 split-tunnel aclipsec
vpngroup vpn3 idle-time 1800
ca identity abcd 192.168.1.5:/certsrv/mscep/mscep.dll
ca configure abcd ra 1 20 crloptional
Log:
SAKMP (0): Checking ISAKMP transform 1 against priority 10 policy
ISAKMP: hash SHA
ISAKMP: life duration (VPI) of 0x0 0x20 0xc4 0x9b
ISAKMP (0): atts are not acceptable. Next payload is 3
ISAKMP (0): Checking ISAKMP transform 2 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 3 against priority 10 policy
ISAKMP: hash SHA
ISAKMP: auth RSA sig
ISAKMP (0): Checking ISAKMP transform 4 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 5 against priority 10 policy
ISAKMP: hash SHA
ISAKMP: default group 2
ISAKMP (0): Checking ISAKMP transform 6 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 7 against priority 10 policy
ISAKMP: hash SHA
ISAKMP (0): Checking ISAKMP transform 8 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): Checking ISAKMP transform 9 against priority 10 policy
ISAKMP: hash SHA
ISAKMP: default group 1
ISAKMP (0): Checking ISAKMP transform 10 against priority 10 policy
ISAKMP: hash MD5
ISAKMP (0): deleting SA: src x.x.x.x, dst y.y.y.y
09-11-2002 02:01 PM
Sure looks like it. Get with the TAC on this one for sure.
