Will conduit take precedence over statefull inspection?
jsluzewski
Will the conduit statement:
conduit permit ip host host_ip any
allow out-of-session packets (for which firewall does not have entry in its connection table) arriving due to asymetric routing?
rais
Level 7
Level 7
Yes, all IP packets will be allowed.
HTH.
No, this is not correct. The conduit statement specified will allow SYN packets sourced from anywhere into this host but once the conn is created, the PIX will check Sequence #, ACK #, flags, etc. via the ASA to determine if the packets are allowed to pass. If the packets do not match a current conn, the PIX will silently drop the packet.
Scott
Scott,
Thanks for the correction and clarification.
Rais.
