HA Duo Authentication Proxy
dianawinsky
Has anyone experienced the configuration of HA setup for duo authentication proxy without a load balancer? or is a load balancer required?
DuoKristina
Hey @dianawinsky - are you aware that in addition to the technical documentation available at duo.com/docs, there is also a public knowledge base at help.duo.com? You can search for additional information there.
For example, a search for "authentication proxy high-availability" has this article as the first result. Within that article it is explained that a load-balancer is needed for active/active HA. You can consider this the documentation that proves there is no "real HA" in the Authentication Proxy application itself.
If you are setting up the Authentication Proxy for AD or LDAP directory sync, or SSO AD authentication, there is some redundancy provided if you add multiple Authentication Proxy servers to those setups with a common configuration (i.e. identical [cloud] sections for sync, or multiple connected servers for SSO). In these configurations there is failover when a connected Authentication proxy selected at random for use doesn't respond, but you cannot select or specify a specific proxy to use, set an order for use or failover, or see anything about the proxy other than the connected status.
Duo, not DUO.
9 Replies 9
rschlayer
Level 4
Level 4
That depends on the Authentication Source going to the Proxy. Normally devices (such as ASA or other Firewalls) allow you to enter multiple radius servers in their configuration.
What device are you looking to set up?
I mean, is the usual setup of a duo authentication proxy installed on a Windows server or Linux server can be HA? How to set HA in On-prem and DR On-prem?
Yes. You should install 2.
We put one in each prod, one in dr and both are configured in the various services that are using them. That way you can patch each one with no down time.
You just have to be sure the services using them will support that.
So if I already configured the main one, it should be the same in DR? like there's no need to configure another external directory in DUO, it's just that I need to install duo auth proxy in DR on-prem like I did in main? Is there a guide for this HA setup in order for me to understand the procedures clearly?
rschlayer
Level 4
Level 4
There is no real "HA" setup, you simply install two DUO Authentication proxy in your environment. This way you have two servers providing the DUO service. You then point your relevant devices to these duo servers and that is it.
Do you have documentation to prove your input that there is no real "HA" setup?
So how will I know if this auth proxy is primary and if down?
DuoKristina
Duo, not DUO.
That is noted. It's clear to me now. Thanks. I'm just curious about Duo, and I don't understand some of the documentation. I'm doing also testing with other stuff that can be integrated with Duo
