04-06-2025 02:13 AM
Can we use DUO MFA/2FA for SSH client tools such as PuTTY, etc.? I see the Unix application guide, but is the SSH client tools part of that guide?
Solved! Go to Solution.
04-11-2025 05:41 AM
You use PuTTy and similar tools to SSH to some remote *nix system. You install Duo Unix on that remote system, and when you connect to it using PuTTy or whatever ssh client, you go into the 2FA logon flow.
04-11-2025 05:41 AM
