Issue with Guacamole and NGINX
officialJCReyes
Hello everyone,
I’m having a weird issue while using Duo with Guacamole and NGINX. Currently, I am able to log in with no issue using my local address: http://10.10.10.6:8080/guacamole
, however, whenever I try to use my domain https://remote.example.com I get the following error message: 2X_6_6024cbb70111fdfbc1fcb6b78b60a75570ddfd72.png
If I press continue, I get the following error:
Does anyone have any idea as to what may be going on?
nug
I’m having exactly the same issue - did you ever find a solution?
Amy2
Level 5
Level 5
Hi @officialJCReyes and @nug - I recommend contacting Duo Support for assistance with troubleshooting this issue. I’m not familiar with Guacamole or NGINX myself, and I’m not finding a lot of resources I could use to help you with this. Our support folks will definitely be better suited to help!
