Cisco Aironet 1552S Directional Antennas
darryl.spurr1
Have a project were there is a length of straight road about 800 meters long.
The 1552S comes with omnidirectional aerials and would like to know if directional aerials can be fitted to maximise range.
Darryl
Amit Shah
You can check any of below mentioned antennas.
AIR-ANT2413P2M-N=,AIR-ANT5114P2M-N=,AIR-ANT2588P3M-N=
Amit
Hi Amit,
The last one looks ok. Notice it has three connections so will have to have a closer look at this and see if there are any issues connecting to the 1552S.
