07-30-2018 01:17 AM
I am unable to configure voice vlan in SG300-28PP...Is this switch not supported this feature???
08-01-2018 03:39 AM
My name is Ritesh Sharma from Cisco TAC.
The voice VLAN option is supported by SG300-28PP switch.
You can enabled the same by accessing the switch GUI.
Go to VLAN Management >> Voice VLAN >> Properties >> Enable.
Please mark it as helpful if it resolves your issue.
Ritesh Sharma
11-07-2019 01:32 PM
Is it possible to enable more than one voice vlan on the switch?
