Rebuild the RAID1 with MegaRAID 9220-8i on UCS C22
atcga1925
My Windows Server failed to install after process is done.  I need to fresh configuration on RAID1 that actually delete Virtual Drive to rebuild but I have an error that storaged RAID subsystem not ready yet.  How can I delete and rebuild the RAID1 VD?  Please help.
fogemarttt
Restart your server, while looking at the console, when you will get tips to go the the Gui of your controller manager , go through (CTRL + Y) or else.
with your mouse, you can go to the controller disk and remove the VD. it is very simple.
