64 bit Multi-pane client?
Jason Rossi
I have a client who cannot use SASD nor AVP, but can use IE on 64 bit windows. Funny thing is I can't find the driver for 64 bit windows multipane client anymore, I can only fine drivers for 32 bit windows.
Normally I would just install AVP and then IE would work, but unfortunately due to his unique configuration installing AVP or SASD is not an option. I can't locate the 64 bit multi pane client. We are on 7.7 Anyone know where I can find it?
Scott Olsen
Level 6
Level 6
It is exceedingly complicated to get the 64bit browser applet to install and function reliably.  A few things I've noted:
- You can't have both the 32bit and 64bit 'Cisco Multi-Pane Video Surveillance Client' installed concurrently on a workstation in our experience.
- We've had to ensure IE was configured for Enhanced Protected Mode (EPM) for the VSOM FQDN/IP prior to initially visiting Operations Manager.  If IE is successfully running a 64bit frame on first site visit (and doesn't already have the 32bit client installed!) the installation for the 64bit client *should* initiate. *Note: We've also noticed that IE tends to crash the first time it attempts to load the client.  Subsequent attempts succeed.
- You *can* find the Viper64 and Viper32 .CAB packages on the VSOM server itself.  These can be opened with a CAB explorer (or similar) to acquire the actual .MSI packages which could be used for workstation deployment.  Unfortunately, I don't have access to a VSOM server at the moment to verify the path where you can find them, and I can't seem to recall it from memory!
As soon as I get the opportunity to complete my rebuild of our lab server on 7.8, I'll try and remember to check the path for you.
Cheers!
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
