Badge Facility Code Mismatch
Steve Warren
We have cisco physical access manager and gateway running version 1.1.0 software.  The gateway has been register with the pam server and a 10 Wire Wiegand template attached.  We have also created a location and added a door to that location. The dooor was also added to a access policy permiting access to the door.  User was created and assigned to a badge.  The access policy created was also assigned to the badge.
The badge is a microprox tag and the card reader is a HID MiniProx.  When I swipe the tag the pam server displays the following error message:
Door Deny Access Badge Facility Code Mismatch
I did enter the facility code as displayes on the tag.
I have a couple of questions:
Should I wire the following devices as normally open or normally close:
Door sensor
REX
Card reader
Door Lock
Steve Warren
Finally got it to work. Apparently the facility code is a single digit. The lock does not change to unlock after pressing the rex button.
