CIVS-IPC-6030 Outdoor VR HD Dome Camera Wall Mount needed
Scott Donahue
Trying to find out if there is a gooseneck type of mount available for this camera.  This is the one of the new 6000 series cameras and is for use outdoors but don't want to mount directly to the wall.  Data spec sheet does not show mounting template or options. If a goose-neck adapter is not available can anyone share the mounting template so I can try to find a third party who might have a wall mount bracket that would work.
Looking for something similar to the image below where the "Conduit Adapter" could be used inbetween the CIVS-IPC-6300 and a gooseneck wall mount.
Scott
Check vivotek.com for camera accessories.
Thank you Cory, would you happen to know the part number conversion?
Hi Cory,
Thank you SO MUCH... I have forwarded the information to our partner doing the install and now hopefully we will be able to move forward with this new camera.
Scott
