disable alarm sound on MSP
christmarcel
Hi All,
does anyone knows step by step how to disable the "beep" sound on MSP?
Marcel
Hi Marcel,
If the alarm is coming from the MegaRAID, you can either:
Browse to the server's VSMC web page (http://
or
ssh into the server and use this command:
/opt/MegaRAID/MegaCli/MegaCli -adpsetprop AlarmSilence -aALL
Sincerely,
Dirk Christeaens
Hi Marcel,
or
Sincerely,
Dirk Christeaens
Hi Dirk,
Thanks man
one more question, is there any other thing besides raid/power causing the server to generate the alarm?
Marcel
Hi Marcel,
During the Power-On Self-Test (POST), the BIOS will check for problems. If a problem is found, the BIOS will activate an alarm, turn on LED indicators or display a message on the monitor.
For example these are know to result in audible alerts:
1 long and two short beeps - video configuration error
1 continuous long beep - overheat (Overheat LED will be on)
1 long beep and 1 short pause - memory not detected
There may be others as well. For example, a problem with the keyboard (like stuck key) may also result in an audible alert.
Best is to check the POST error on the monitor and/or check the system LEDs if you want to be sure what's causing the alert.
Sincerely,
Dirk Christeaens
