First time logged in SASD - Reset Password problem
Tuan Pham
With VSM 7.0.1 after you created a new user account in OM. When you launch SASD(the client) and login for the first time. A message pop-up:
"Operation failed:Password expiered or user logged in for the first time. Please reset the password"
but there is no place on that windows that I can find to reset the password. Does anyone seen this at all or am I missing something???
Tuan Pham
Okay. This is kinda 'dump' from the an application. I just figured it out. In order to login to SASD on the first-time, you must first login to OM. There, it will ask you to change your password. I wish they have an option that you can uncheck in OM so it won't ask you...
