I need a list of supported cameras for VSOM 6.3.2
Steven Jorgens
I need a list of supported cameras for VSOM 6.3.2.   The link that I had saved previously with this info for different versions of VSOM no longer exists in Cisco.com world.  Please help.
Thank you.
Scott Olsen
Level 6
Level 6
I believe the list you are looking for can be accessed via the Cisco Emerging Technologies portal at:
https://www.ciscoet.com/resource/vsm-632-mr2-supported-devices-list
Hope this helps!
Scott Olsen
Solutions Specialist
Bulletproof Solutions Inc.
Web: www.bulletproofsi.com
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
Scott Olsen
Level 6
Level 6
Hope this helps!
Scott Olsen
Thank you, but that list is for the MR2 release.  I need the list for the non MR release.
Steve J.
There's an Appendix for the 6.3.2 VSM API documentation that I think is about as close as you're going to get:
http://www.cisco.com/c/en/us/td/docs/security/physical_security/video_surveillance/network/vsm/api/reference/vsmapi/srcTypeAppdx.html
Hope this works out for you.
Cheers,
Scott Olsen
