Problem with adding camera to media server
shodan524
Level 2
Level 2
Hi everybody.
We have problem with adding cameras to media server. When adding some cameras the error below appears:
Operation failed: Media server reported the error Failed to create MediaServer capture driver for archName bd484b3b-6028-4896-9713-b470eaaaf2ad_vs1_r periphId 10007
Some times it appears with cameras which worked before.
May be someone faced with this kind of problem. What can cause this problem.
Please advice.
i guess we are hitting a defect here, i would recommend to upgrade to 7.2.2 or open a TAC case for further assistance on this issue.
14 Replies 14
Raghav-Rao
1. what is the VSM version? specific version?
2. what model of camera are you trying to add?
3. what type of camera template is used?
4. could share the output of the below commands
On servers running VSM 7.2.0 on SLES 10 SP1
 # sudo /usr/bin/lsof -p  $(/sbin/pidof xvcrman) | grep -c smd
On servers running VSM 7.2.0 on RHEL 5.8
 # sudo /usr/sbin/lsof -p  $(/sbin/pidof xvcrman) | grep -c smd
1. VSM version is 7.2.0
2. Camera models are 3520, 6020, 6030
3. We are creating camera specific templates for each type of camera
4. From VSOM
[localadmin@localhost ~]$ sudo /usr/sbin/lsof -p  $(/sbin/pidof xvcrman) | grep -c smd
lsof: no process ID specified
lsof 4.78
 latest revision: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/
 latest FAQ: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/FAQ
 latest man page: ftp://lsof.itap.purdue.edu/pub/tools/unix/lsof/lsof_man
 usage: [-?abhlnNoOPRstUvVX] [+|-c c] [+|-d s] [+D D] [+|-f[gG]] [+|-e s]
 [-F [f]] [-g [s]] [-i [i]] [+|-L [l]] [+m [m]] [+|-M] [-o [o]]
 [-p s] [+|-r [t]] [-S [t]] [-T [t]] [-u s] [+|-w] [-x [fl]] [-Z [Z]] [--] [names]
Use the ``-h'' option to get more help information.
From Media Server
[localadmin@MediaServer6 ~]$ sudo /usr/sbin/lsof -p  $(/sbin/pidof xvcrman) | grep -c smd
4054
should we upgrade to 7.2.2 or may be 7.5.0 or 7.5.1 ?
HI,
it's always good to have the latest version installed.
from the above log, look like you have got the wrong package. could you check what OS is running on the server with below command.
cat /etc/issue
considering OS, SUSE or Red Hat version, please have the package downloaded from Cisco.com and proceed with upgrade.
let me know, if you have any questions.
our version is Red Hat 5.8
1. was the upgrade successful?
2. what stage is upgrade now?
3. /usr/BWhttpd/upgrade/server/upgrade.log, what does this log say?
4. rpm -qa Cisco*
5. vscheck
1. No,install wasn'r successful
2. I have upgraded every server from CLI, all previous configuration lost
now i added all cameras, but the error below appears:
Failed to parse view description XML, error code: c00ce169. reason = Failed to parse XML, error code: -1072897687. Reason: 'PostMetadata' violates enumeration constraint of 'PTZControl PTZConfig MDConfig ViewRecording Record ExportVideo ClipVideo ViewLive CameraConfig ListenToAudio'. The attribute 'Name' with value 'PostMetadata' failed to parse.
What can be problem
i haven't seen this error before.
1. what is the IE version?
2. have you uninstalled the VSM plugins and re-installed the plugins for 7.5.X?
3. could you share with us the snap shot of the error message?
4. is this issue with all the cameras or certain model? what type of template is been used?
5. check the commands "service cisco status" and "vscheck"
that was the error fo IE i think. Because aftrer PC restart everything is OK. Now we can see cameras from VSOM web browser.
Thank you for your effort
I'm glad it worked for you, are you able to add cameras now?
NP, I'm glad, i could help.
Yes,
Now I can add cameras. I'll check  recordings for a few days.
can you please describe what does this warning means?
Pending software Upload - MS-s/Vsom do not have these software uploaded
Also we have another issue.
When viewing from monitoring window we can see only last 10-15 minutes of recordings every time when we look at it. We cannot see old recordings.
What should we check?
I have tried to upgrade to 7.5.1 version via VSMC, here is the result:
2014-10-20 11:50:33.??? [ bash(25358) ] Expanding the upgrade file Cisco_VSM-7.5.1-007i-rhel5.zip
Archive:  /usr/BWhttpd/upgrade/server/download/Cisco_VSM-7.5.1-007i-rhel5.zip
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_AMQBroker-7.5.1-1.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_MPClient-7.5.0-24.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_SASD-7.5.0-26.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_Tomcat-7.0.37-2.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSBase-7.5.1-043d-rhel5.8.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSDrivers-7.5.1-043d-rhel5.8.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSMC-7.5.1-004.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSMS-7.5.1-043d-rhel5.8.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSOM-7.5.1-4-rhel5.8.i386.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSRecorder-7.5.1-043d-rhel5.8.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/Cisco_VSTools-7.5.1-043.noarch.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/jre-7u17-linux-i586.rpm
  inflating: /usr/BWhttpd/upgrade/server/workspace/upgrade_main.sh
  inflating: /usr/BWhttpd/upgrade/server/workspace/VSM-version.xml
2014-10-20 11:50:43.??? [ bash(25358) ] Platform:rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] Cisco_VSBase-7.5.1-043d-rhel5.8.rpm is for the right platform rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] Cisco_VSDrivers-7.5.1-043d-rhel5.8.rpm is for the right platform rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] Cisco_VSMS-7.5.1-043d-rhel5.8.rpm is for the right platform rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] Cisco_VSOM-7.5.1-4-rhel5.8.i386.rpm is for the right platform rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] Cisco_VSRecorder-7.5.1-043d-rhel5.8.rpm is for the right platform rhel5.8
2014-10-20 11:50:43.??? [ bash(25358) ] OS Validation: pass
2014-10-20 11:50:43.??? [ bash(25358) ] Upgrade package is targeted on a right platform
2014-10-20 11:50:43.??? [ upgrade_main.sh(25622) ] Upgrade script initialized
2014-10-20 11:50:43.??? [ upgrade_main.sh(25622) ] User RPM list not specified
2014-10-20 11:50:43.??? [ upgrade_main.sh(25622) ] Building a User RPM list
2014-10-20 11:50:43.??? [ upgrade_main.sh(25622) ] No VSOM Response URL specified
2014-10-20 11:50:43.??? [ upgrade_main.sh(25622) ] No Wowza RPM found for installation
2014-10-20 11:50:50.??? [ upgrade_main.sh(25622) ] Upgrade failed. Upgrade script failed. Upgrading from unsupported version to VSOM-7.5.1
2014-10-20 11:50:50.??? [ bash(25358) ] upgrade_main.sh failed with error 29.
2014-10-20 11:50:50.??? [ bash(25358) ] ---- Start output from upgrade_main.sh ----
2014-10-20 11:50:50.??? [ bash(25358) ] 7 Upgrade script initialized
2014-10-20 11:50:50.??? [ bash(25358) ] ls: *Wowza*.rpm: No such file or directory
2014-10-20 11:50:50.??? [ bash(25358) ] 11 Upgrade failed. Upgrade script failed. Upgrading from unsupported version to VSOM-7.5.1
2014-10-20 11:50:50.??? [ bash(25358) ] ---- End output from upgrade_main.sh ----
What can cause problem?
