Removing built-in RFID tags on Catalyst 9k series switchgear
kedwards34
Without opening a TAC yet, has anyone looked into the ability to remove the RFID tags from the Catalyst 9k series switchgear?  The fixed config is easy enough, but the modular switches have the RFID tags embedded in the Line Card ejector arms (as well as the chassis and fan tray).  Also if the RFID tags are removed, does this affect future warranty/replacement issues further down the line?
I don't have an answer as to why I would want to remove these, but I'm interested anyway.
Leo Laohoo
If the hardware will be deployed in a defense- or intelligence-related network then it is best reaching out to your Cisco AM/SE.
