VSOM Mobile on Kindle Fire
derrickmunro
How exactly am I supposed to use the Google Play Store with Kindle?  Do you have any instructions for setting up VSOM Mobile on a Kindle Fire?
derrickmunro
I had to download ES3 from the Amazon Store to my kindle, and install the APK direct.  Does anyone know the proper way to do this?
There may be no _proper_ way to do this.  The Kindle Fire is basically a "walled-garden" type of device that I don't believe has native access to the Google Play Store.  Many of the less powerful android based tablets have their own "app stores" created by the vendors that are carefully managed and restrict what can/should be installed on the devices; so as to prevent people from installing applications that the hardware platform just doesn't have the horsepower to deliver on.
Were you actually able to obtain and install the APK for VSOM Mobile on a Kindle Fire?  I'm curious how it works out for you.
Cheers!
Scott Olsen Solutions Specialist Bulletproof Solutions Inc. Web: www.bulletproofsi.com
