How to remove push option and have only text or call in DUO
lynnp1
Hello All
we currently use Duo with VPN and it does the push option (where you have to approve or deny) however Duo will no longer support iOS10 or Android 6 or below phones with the push option. How can I change those phones only to use the call or text option instead of the push option?
Thank You
Lynn
mkorovesisduo
Level 4
Level 4
Hi Lynn, when we end support for iOS 10 and Android 6 on July 28, 2019, push and app-generated passcode authentications will continue to function on installed apps. We have no plans to terminate functionality for these features of the app on older OSes.
The end-of-support milestone simply means that our development and technical support engineering teams will no longer be able to help troubleshoot issues with the application on iOS 10, Android 6, or older.
However, if you would like to restrict which authentication methods can be used, I recommend considering an authentication methods policy. In addition, we will never automatically send a push to a user if they do not have Duo Mobile installed and activated. They may utilize other authentication methods, such as phone callback, instead of Duo Push.
