ACS 4.0 Not Logging Mikrotik VSA
mpenney
Hi All,
I'm currently having an issue where specific vendor attributes from my Mikrotik NAS are not being logged int the Local accounting CSV.  I installed the VSA's and they show as an option under system/logging in which I choose to log this case "Mikrotik-Host-IP", but just don't log (field shows up but always blank.  Not sure why.  they show up in the RDS.log file (see BOLD below), just not in the log file.
Any help appreciated,
Mike
RDS 01/27/2012 14:55:19 D 0245 1948 Request from host 192.168.16.10:1813 code=4, id=32, length=249 on port 56822
RDS 01/27/2012 14:55:19 E 3281 1948 (Unknown VSA Vendor ID 14122)
RDS 01/27/2012 14:55:19 I 3017 1948     [040] Acct-Status-Type                    value:  2
RDS 01/27/2012 14:55:19 I 3017 1948     [049] Acct-Terminate-Cause                value:  3
RDS 01/27/2012 14:55:19 I 3017 1948     [061] NAS-Port-Type                       value:  19
RDS 01/27/2012 14:55:19 I 2999 1948     [031] Calling-Station-Id                  value:  00:26:4A:C2:E0:7E
RDS 01/27/2012 14:55:19 I 2999 1948     [030] Called-Station-Id                   value:  SFO
RDS 01/27/2012 14:55:19 I 2999 1948     [087] NAS-Port-Id                         value:  vlan3
RDS 01/27/2012 14:55:19 I 2999 1948     [001] User-Name                           value:  JTWdefViD1
RDS 01/27/2012 14:55:19 I 3017 1948     [005] NAS-Port                            value:  -2139001759
RDS 01/27/2012 14:55:19 I 2999 1948     [044] Acct-Session-Id                     value:  80816c61
RDS 01/27/2012 14:55:19 I 3042 1948     [008] Framed-IP-Address                   value:  192.168.64.152
RDS 01/27/2012 14:55:19 I 3047 1948     [026] Vendor-Specific                     vsa id: 14988
RDS 01/27/2012 14:55:19 I 3089 1948           [010] Mikrotik-Host-IP              value:  192.168.64.152
RDS 01/27/2012 14:55:19 I 2999 1948     [025] Class                               value:  CACS:0/3d00bf/c0a8100a/2155965537
RDS 01/27/2012 14:55:19 I 3036 1948     [055] Event-Timestamp                     value:  27-01-12 15:08
RDS 01/27/2012 14:55:19 I 3017 1948     [042] Acct-Input-Octets                   value:  550317
RDS 01/27/2012 14:55:19 I 3017 1948     [043] Acct-Output-Octets                  value:  23197449
RDS 01/27/2012 14:55:19 I 3017 1948     [052] Acct-Input-Gigawords                value:  0
RDS 01/27/2012 14:55:19 I 3017 1948     [053] Acct-Output-Gigawords               value:  0
RDS 01/27/2012 14:55:19 I 3017 1948     [047] Acct-Input-Packets                  value:  8495
RDS 01/27/2012 14:55:19 I 3017 1948     [048] Acct-Output-Packets                 value:  16346
RDS 01/27/2012 14:55:19 I 3017 1948     [046] Acct-Session-Time                   value:  1998
RDS 01/27/2012 14:55:19 I 2999 1948     [032] NAS-Identifier                      value:  AWG
RDS 01/27/2012 14:55:19 I 3017 1948     [041] Acct-Delay-Time                     value:  0
RDS 01/27/2012 14:55:19 I 3042 1948     [004] NAS-IP-Address                      value:  192.168.16.10
camejia
Level 3
Level 3
Can you please share the Mikrotik VSA dictionary please? I have not seen this issue before.
Best Regards.
This is from the ini file, thanks for your response
[User Defined Vendor]
Name=Mikrotik
IETF Code=14988
VSA 13=Mikrotik-Advertise-Interval
VSA 12=Mikrotik-Advertise-URL
VSA 3=Mikrotik-Group
VSA 10=Mikrotik-Host-IP
VSA 11=Mikrotik-Mark-Id
VSA 8=Mikrotik-Rate-Limit
VSA 9=Mikrotik-Realm
VSA 1=Mikrotik-Recv-Limit
VSA 14=Mikrotik-Recv-Limit-Gigawords
VSA 6=Mikrotik-Wireless-Enc-Algo
VSA 7=Mikrotik-Wireless-Enc-Key
VSA 4=Mikrotik-Wireless-Forward
VSA 5=Mikrotik-Wireless-Skip-Dot1x
VSA 2=Mikrotik-Xmit-Limit
VSA 15=Mikrotik-Xmit-Limit-Gigawords
VSA 21=Mikrotik-Wireless-Comment
[Mikrotik-Advertise-Interval]
Type=INTEGER
Profile= MULTI IN OUT
[Mikrotik-Advertise-URL]
Type=INTEGER
[Mikrotik-Group]
Type=STRING
[Mikrotik-Host-IP]
Type=IPADDR
Profile= IN
[Mikrotik-Mark-Id]
Type=STRING
[Mikrotik-Rate-Limit]
Type=INTEGER
[Mikrotik-Realm]
Type=STRING
[Mikrotik-Recv-Limit]
Type=INTEGER
[Mikrotik-Recv-Limit-Gigawords]
Type=INTEGER
[Mikrotik-Wireless-Enc-Algo]
Type=INTEGER
[Mikrotik-Wireless-Enc-Key]
Type=INTEGER
[Mikrotik-Wireless-Forward]
Type=INTEGER
[Mikrotik-Wireless-Skip-Dot1x]
Type=INTEGER
[Mikrotik-Xmit-Limit]
Type=INTEGER
[Mikrotik-Xmit-Limit-Gigawords]
Type=INTEGER
[Mikrotik-Wireless-Comment]
Type=STRING
Profile= IN
