ACS 5.4 and Juniper J-Web
Simon Young
I have set up an ACS 5.4 box and have some test devices connected to it.
Cisco and Juniper, both working fine using TACACS
I can connect to both using SSH or Telnet but my problem is the J-Web Juniper GUI
I can access the J-web no problem with the root account.
I can not seem to get it to work, no matter what I try. Here is my shell from the ACS box
And the following Juniper configuration.  I have tried binding the local-user-name attribute to both the remote and remoteadmin with no luck. Anyone have any ideas how I can resolve this??? Or if its even possible?
version 9.6R1.13;
system {
    host-name Juniper-Firewall;
    authentication-order [ tacplus password ];
    root-authentication {
        encrypted-password "$1$1tRuy9o2$LwSPxNwe4XGNMOMIMo1pd1"; ## SECRET-DATA
    tacplus-server {
        10.251.200.25 {
            secret "$9$zaUL6/AtuOIRS5QF/CuEhws2"; ## SECRET-DATA
            timeout 10;
            single-connection;
    accounting {
        events [ login change-log interactive-commands ];
        destination {
            tacplus;
    login {
        user admin {
            uid 2001;
            class super-user;
            authentication {
                encrypted-password "$1$MNUZBLFW$X2sJL/UTgRYcgBNV4RLe.0"; ## SECRET-DATA
        user remote {
            full-name "Remote User";
            uid 2025;
            class operator;
        user remoteadmin {
            full-name "Remote Admin";
            uid 2026;
            class super-user;
    services {
        ssh;
        telnet;
        web-management {
            https {
                system-generated-certificate;
                interface fe-0/0/0.0;
Jatin Katyal
I was working on a almost similar issues today and he confirmed that he is able to access J-WEB with the tacacs credentials.You may check his config here: https://supportforums.cisco.com/message/3953224#3953224
Going through your config it seems you have not defined/created classes like he did:
for example:
login {
    class RO-CLASS {
        permissions [ view view-configuration ];
    class RW-CLASS {
        permissions all;
    user JUNOS-RO {
        uid 2000;
Jatin Katyal
- Do rate helpful posts -
~Jatin
17 Replies 17
Jatin Katyal
What do you see in acs/tacacs logs while authenticating for J-web?
Is that possible we can run the packet capture on the ACS 4.2 ( in case it is windows)?
Jatin Katyal
~Jatin
Hi Jatin
I am running ACS 5.4, so I am not sure what you mean when you say packet capture on 4.2 (I don't have this)
Which logs should I access? And is there an issue with windows?
sorry, my bad. I was helping someone on ACS 4.2 as well.
Look at tacacs authorization under logging and monitoring. I mentioned windows because in case of appliance either we have to take tcpdump or span the switch port to take packet capture.
Jatin Katyal
~Jatin
I am not seeing any recent entries in the tacacs authorization. I can see the SSH highlighted below. I am not seeing any http logging, not sure if I have to turn something on in ACS?
My Juniper is stating, failure with the Tacacs user and success with the root user?
root@Juniper-Firewall> show log messages
May 30 15:41:32 Juniper-Firewall clear-log[11338]: logfile cleared
May 30 15:37:00  Juniper-Firewall last message repeated 2 times
May 30 15:41:45  Juniper-Firewall checklogin[11346]: WEB_AUTH_FAIL: Unable to authenticate httpd client (username Jweb)
May 30 15:47:01  Juniper-Firewall checklogin[11358]: WEB_AUTH_SUCCESS: Authenticated httpd client (username root)
May 30 15:48:26  Juniper-Firewall checklogin[11399]: WEB_AUTH_FAIL: Unable to authenticate httpd client (username Jweb)
May 30 15:48:55  Juniper-Firewall sshd[11402]: Accepted password for jweb from x.x.x.x port 54501 ssh2
have you gone through this
http://kb.juniper.net/InfoCenter/index?page=content&id=KB24437
Jatin Katyal
~Jatin
OR
You may try this:
  1. In the J-Web user interface, select Configure>System Properties>User Management.
  2. Click Edit. The Edit User Management dialog box appears.
  3. Select the Authentication Method and Order tab.
Just make sure the first authentication method is tacacs and fallback is local.
Jatin Katyal
~Jatin
I had seen that post and it is exactly the same as what I am seeing but my settings were already configured correctly.
I have doubled checked the settings via Jweb and they are as expected.
I have no idea why this doesn't work
I could only see the below listed error.
Is there any detailed debbuging or logging related to tacacs or aaa that we can run and further isolate this issue.
We can also run the packet capture on the ACS side and take a look.
Jatin Katyal
~Jatin
how do i run the packet capture on the acs?
Well you can take tcpdump and that can only be done via bash shell/root access. I may not be able to help you here as there is a special patch that need to be applied on the ACS before we run tcpdump. For now, would it be possible for you to span the switch port where acs is connected.
do share the tacacs key so that we can decode it.
Jatin Katyal
~Jatin
I spanned the Juniper connected port and then attempted to connect to the GUI
I could see my https sessions within wireshark but there was no inidication of any Tacacs authentication occuring. I'd at least expect some TCP traffic on port 49?
I repeated the logon via the root account and saw exactly the same thing, except that the root acount successfully logged into the device
I am sure that this is a mapping issue in that my user (jweb) is not mapping correctly within the command set.
I have vsys set as mandatory root and privilege as mandatory but this is isn't working (in my opinion)
since ssh is working with tacacs there should not be a port tco 49 issue.
The below listed config confirms that https is enabled using self-signed certificate.
services {
        ssh;
        telnet;
        web-management {
            https {
If I am not wrong, you don't even see passed or failed authentication on ACS under tacacs authentication.
Jatin Katyal
~Jatin
Hi Jatin
Good point about the SSH, I have been looking at this too long
You are correct, I see nothing in the ACS tacas authentication report for my HTTPS connections
This is a SSH test followed by a Telnet test, which always work
May 31,13 1:55:49.256 PM
May 31,13 1:55:49.230 PM
jweb Juniper Firewall
Vendor:Vendor:Juniper, Device Type:All Device Types:Firewall, Location:All Locations:Marlow
J-Web
Internal Users
All Groups:Jweb
nhc0-dev-acs001
May 31,13 1:55:32.216 PM
May 31,13 1:55:32.186 PM
Is there any specific section on juniper where you need to point the J-WEB authentication towards tacacs first and then local. I feel that section is still checking the tacacs user against the local database and getting failed.
Jatin Katyal
~Jatin
