C2960 host-mode multi-domain Cisco phone does not go to Voice Domain
Hi everybody
I am working on deploying dot1.x through our company. I am stuck on configuring Cisco Phones to go on a correct VLAN when host-mode multi-domain option is used. I tried it on two C2960 switches with two different images. No matter what I do, the phone goes to Domain:  DATA and cannot connect to the network as most likely it is in a wrong VLAN. ISE is showing port as authenticated and MAB works fine. When I configure host-mode multi-host, the phone gets a correct VLAN and can tall to the network.
Here is what I use:
  • C2960S-48FPS-L with C2960S-UNIVERSALK9-M or C2960 SI with c2960-lanlitek9-tar.150-2.SE7
  • Cisco Phone 7960 and 7962
  • ISE  1.3.0.876
Here is the current port configuration:
interface GigabitEthernet1/0/1
switchport access vlan 2
 switchport mode access
 switchport voice vlan 703
 authentication host-mode multi-domain
 authentication order mab dot1x
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
end
Here is the output of show authentication session inter Gig1/0/1
MAC Address:  0013.1a58.xxxx
IP Address:  Unknown
User-Name:  00-13-1A-xx-xx-xx
Status:  Authz Success
Domain:  DATA
Oper host mode:  multi-domain
Oper control dir:  in
Authorized By:  Authentication Server
Vlan Policy:  N/A
Session timeout:  5400s (local), Remaining: 5384s
Timeout action:  Reauthenticate
Idle timeout:  N/A
Common Session ID:  0AF301450000000C001F3391
Acct Session ID:  0x00000010
Handle:  0x0400000D
Thanks for your help.
Looks like youre missing the device-class=voice attribute in your authz profile.
7 Replies 7
jan.nielsen
Level 7
Level 7
What is the content of your authorization result that is used for the phone ?
Hi Jan
Thank you for your response.
This test was run with only the phone connected to the switch.
This is what I see on the ISE server:
Steps
11001
Received RADIUS Access-Request
11017
RADIUS created a new session
11027
Detected Host Lookup UseCase (Service-Type = Call Check (10))
15049
Evaluating Policy Group
15008
Evaluating Service Selection Policy
15048
Queried PIP - Radius.Service-Type
15048
Queried PIP - Radius.NAS-Port-Type
15004
Matched rule - MAB
15041
Evaluating Identity Policy
15006
Matched Default Rule
15013
Selected Identity Source - Internal Endpoints
24209
Looking up Endpoint in Internal Endpoints IDStore - 3C:CE:73:58:xx:xx
24211
Found Endpoint in Internal Endpoints IDStore
22037
Authentication Passed
15036
Evaluating Authorization Policy
15048
15004
Matched rule - ARR-MAB
15016
Selected Authorization Profile - PermitAccess
11002
Returned RADIUS Access-Accept
And this is what I see on the switch:
May 11 09:06:39.844: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
May 11 09:06:40.846: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
May 11 09:06:50.414: %AUTHMGR-5-START: Starting 'mab' for client (3cce.7358.xxxx) on Interface Gi1/0/1 AuditSessionID 0AF30145000000030016E90A
May 11 09:06:50.440: %MAB-5-SUCCESS: Authentication successful for client (3cce.7358.xxxx) on Interface Gi1/0/1 AuditSessionID 0AF30145000000030016E90A
May 11 09:06:50.440: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (3cce.7358.xxxx) on Interface Gi1/0/1 AuditSessionID 0AF30145000000030016E90A
May 11 09:06:50.613: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (3cce.7358.xxxx) on Interface Gi1/0/1 AuditSessionID 0AF30145000000030016E90A
Jan, you are the man! :)
This worked as a champ. Rookie mistake I guess.
My mistake was that I assumed this would work on a switch level by CDP, without any ISE config required. And to be fair no documentation I found mentioned anything about this.
Once again thank you for your help.
Lukasz
One thing solved but it is still not working as it should.
When only the phone is connected, everything looks OK. I can ping the phone without a problem. This is an improvement as I could not do this before.
The moment I connect a PC to the phone, pings to the phone drop and it loses config.
The PC network is also unidentified. VLAN on the switch is OK, it gets an IP address but it cannot ping anything. When the PC connects to the port directly, it works OK.
PORT SETTINGS
 authentication violation replace
 mab
end
Switch Console logging output:
May 11 10:13:51.786: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/1: Power granted
May 11 10:13:52.321: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
May 11 10:13:56.888: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
May 11 10:13:59.813: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
May 11 10:14:02.168: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
May 11 10:14:03.169: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
May 11 10:14:10.567: %AUTHMGR-5-START: Starting 'mab' for client (3cce.7358.4796) on Interface Gi1/0/1 AuditSessionID 0AF3014500000010005496D0
May 11 10:14:10.578: %MAB-5-SUCCESS: Authentication successful for client (3cce.7358.4796) on Interface Gi1/0/1 AuditSessionID 0AF3014500000010005496D0
May 11 10:14:10.583: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (3cce.7358.4796) on Interface Gi1/0/1 AuditSessionID 0AF3014500000010005496D0
May 11 10:14:11.495: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (3cce.7358.4796) on Interface Gi1/0/1 AuditSessionID 0AF3014500000010005496D0
Switch(config-if)#
May 11 10:15:11.068: %AUTHMGR-5-START: Starting 'mab' for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:11.094: %MAB-5-SUCCESS: Authentication successful for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:11.094: %AUTHMGR-7-RESULT: Authentication result 'success' from 'mab' for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:11.199: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:14.649: %AUTHMGR-7-FAILOVER: Failing over from 'mab' for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:14.649: %AUTHMGR-5-START: Starting 'dot1x' for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:14.980: %DOT1X-5-SUCCESS: Authentication successful for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:14.980: %AUTHMGR-7-RESULT: Authentication result 'success' from 'dot1x' for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
May 11 10:15:15.310: %AUTHMGR-5-SUCCESS: Authorization succeeded for client (68f7.284a.0cf9) on Interface Gi1/0/1 AuditSessionID 0AF30145000000110055ABAF
Switch authentication session:
Switch#sh authentication sess int gi1/0/1
            Interface:  GigabitEthernet1/0/1
          MAC Address:  3cce.7358.4796
           IP Address:  Unknown
            User-Name:  3C-CE-73-58-47-96
               Domain:  VOICE
     Oper control dir:  both
      Session timeout:  3600s (local), Remaining: 3449s
         Idle timeout:  N/A
    Common Session ID:  0AF3014500000010005496D0
      Acct Session ID:  0x00000018
               Handle:  0xDC000011
Runnable methods list:
       Method   State
       mab      Authc Success
       dot1x    Not run
          MAC Address:  68f7.284a.0cf9
           IP Address:  Unknown
            User-Name:  LAPTOP
               Domain:  DATA
          Vlan Policy:  N/A
      Session timeout:  3600s (local), Remaining: 3513s
         Idle timeout:  N/A
    Common Session ID:  0AF30145000000110055ABAF
      Acct Session ID:  0x0000001A
               Handle:  0xBE000012
       Method   State
       mab      Not run
       dot1x    Authc Success
ISE output:
Phone:
Steps
  11001  Received RADIUS Access-Request
  11017  RADIUS created a new session
  11027  Detected Host Lookup UseCase (Service-Type = Call Check (10))
  15049  Evaluating Policy Group
  15008  Evaluating Service Selection Policy
  15048  Queried PIP - Radius.Service-Type
  15048  Queried PIP - Radius.NAS-Port-Type
  15004  Matched rule - MAB
  15041  Evaluating Identity Policy
  15006  Matched Default Rule
  15013  Selected Identity Source - Internal Endpoints
  24209  Looking up Endpoint in Internal Endpoints IDStore - 3C:CE:73:58:47:96
  24211  Found Endpoint in Internal Endpoints IDStore
  22037  Authentication Passed
  15036  Evaluating Authorization Policy
  15004  Matched rule - TEST-MAB
  15016  Selected Authorization Profile - TEST-VoiceDomain
  11002  Returned RADIUS Access-Accept
PC:
Steps
  15004  Matched rule - TEST_Dot1X
  11507  Extracted EAP-Response/Identity
  12500  Prepared EAP-Request proposing EAP-TLS with challenge
  12625  Valid EAP-Key-Name attribute received
  11006  Returned RADIUS Access-Challenge
  11018  RADIUS is re-using an existing session
  12301  Extracted EAP-Response/NAK requesting to use PEAP instead
  12300  Prepared EAP-Request proposing PEAP with challenge
  12302  Extracted EAP-Response containing PEAP challenge-response and accepting PEAP as negotiated
  12318  Successfully negotiated PEAP version 0
  12800  Extracted first TLS record; TLS handshake started
  12805  Extracted TLS ClientHello message
  12806  Prepared TLS ServerHello message
  12807  Prepared TLS Certificate message
  12810  Prepared TLS ServerDone message
  12305  Prepared EAP-Request with another PEAP challenge
  12304  Extracted EAP-Response containing PEAP challenge-response
  12812  Extracted TLS ClientKeyExchange message
  12804  Extracted TLS Finished message
  12801  Prepared TLS ChangeCipherSpec message
  12802  Prepared TLS Finished message
  12816  TLS handshake succeeded
  12310  PEAP full handshake finished successfully
  12313  PEAP inner method started
  11521  Prepared EAP-Request/Identity for inner EAP method
  11522  Extracted EAP-Response/Identity for inner EAP method
  11806  Prepared EAP-Request for inner method proposing EAP-MSCHAP with challenge
  12523  Extracted EAP-Response/NAK for inner method requesting to use EAP-TLS instead
  12522  Prepared EAP-Request for inner method proposing EAP-TLS with challenge
  12524  Extracted EAP-Response containing EAP-TLS challenge-response for inner method and accepting EAP-TLS as negotiated
  12809  Prepared TLS CertificateRequest message
  12527  Prepared EAP-Request for inner method with another EAP-TLS challenge
  12526  Extracted EAP-Response for inner method containing TLS challenge-response
  12571  ISE will continue to CRL verification if it is configured for specific CA - certificate for LAPTOP
  12571  ISE will continue to CRL verification if it is configured for specific CA - certificate for TestDomainDomain-TEST-CA-1-CA
  12571  ISE will continue to CRL verification if it is configured for specific CA - certificate for TEST-CA-ROOT-CA
  12811  Extracted TLS Certificate message containing client certificate
  12813  Extracted TLS CertificateVerify message
  12509  EAP-TLS full handshake finished successfully
  22072  Selected identity source sequence - TEST_CERT_AD_LOCAL
  22070  Identity name is taken from certificate attribute
  15013  Selected Identity Source - TestDomainDomain.co.uk
  24433  Looking up machine in Active Directory - TestDomainDomain.co.uk
  24325  Resolving identity - LAPTOP
  24313  Search for matching accounts at join point - TestDomainDomain.co.uk
  24319  Single matching account found in forest - TestDomainDomain.co.uk
  24323  Identity resolution detected single matching account
  24700  Identity resolution by certificate succeeded - TestDomainDomain.co.uk
  12528  Inner EAP-TLS authentication succeeded
  11519  Prepared EAP-Success for inner EAP method
  12314  PEAP inner method finished successfully
  11055  User name change detected for the session. Attributes for the session will be removed from the cache
  24355  LDAP fetch succeeded - TestDomainDomain.co.uk
  24435  Machine Groups retrieval from Active Directory succeeded - TestDomainDomain.co.uk
  15048  Queried PIP - TestDomainDomain.co.uk.ExternalGroups
  15048  Queried PIP - Network Access.EapAuthentication
  15004  Matched rule - TEST-WIRED-MACHINE
  15016  Selected Authorization Profile - PermitAccess
  12306  PEAP authentication succeeded
  11503  Prepared EAP-Success
Hi again
I thinks there may be a problem in MAB processing. I noticed that the policy authorized the PC on the MAB profile (still need to figure out why).
I changed the authorization order to dot1x mab and after that both devices are connected.
Looks fine to me, what i am wondering is why your switch does not know the ip addresses of your devices? Did you not enable ip device tracking or dhcp snooping ?
Are you using any access-lists on your ports, that you haven't shown us in your "sh run"?
