Installing Cisco Identity Service Engine
Lajja1234
Hi!
I am trying to install Cisco ISE on VmWare Workstation 10. I have created the VM and when i try to boot the VM with the Cisco ISE .iso file in the drive, I only get the following error " The Cisco Identity Services Engine CD was not found." But i have mounted the .iso file in the CDROM drive..
Anyone got any idea?
/Lajja1234
Saurav Lodh
Level 7
Level 7
Please follow the steps from the below link
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/installation_guide/ise_ig/ise_vmware.html#pgfId-1104790
Yes I have followed that guide.
But when I boot the server, and choose installation type 1, ISE boots and shows med the error mentioned above.
/Lajja1234
maxkru_99
I had this error too. I check md5 summ of my iso file and it was fail.
After I download file again all install successful.
