Additional DUO Authentication Proxies (DAPs)
stevenspray1
Hi!
As per subject, I was merely wondering if the same process of installing a DAP can be followed for any additional DAPs? Merely including them all in the respective config files under ad_client, and, since we are using LDAPS, also using the [authproxy_passwd.exe] tool on each one seperately?
I’ve been perusing a few including…
https://help.duo.com/s/article/authentication-proxy-availability?language=en_US
https://help.duo.com/s/article/3618?language=en_US
https://help.duo.com/s/article/6321?language=en_US
Thanks for helping!
colin_medfisch
Hey @fnanfne,
For the most part, that’s it!
One thing to keep in mind though is that individual Authentication Proxy servers are not aware of each other, so you will need to either 1) configure your RADIUS/LDAP client application to round-robin/failover between servers or 2) configure your own load balancer.
Hope this helps!
Colin
colin_medfisch
Hey @fnanfne,
Hope this helps!
Colin
Yes that’s very helpful thank you!
