ADFS and Duo Proxy in same enviroment
chatataridge
Currently we have Duo performing 2Fa for Office 365 using ADFS. I now need to set up a Duo Proxy server to preform VPN 2Fa for an ASA/ISE vpn deployment.
Is there going to be a conflict in deploying a Duo Proxy and ADFS
DuoKristina
There is no interaction between Duo for ADFS and the Duo Authentication Proxy. It’s fine to install them both in your environment (but we wouldn’t suggest you install the Duo proxy on your AD FA server).
Duo, not DUO.
chatataridge
Kristina
Thank you for your reply.
I am looking for a document to integrate with Cisco ISE for 2Fa but am unable to find a resource from Duo. For compliance reasons we need ISE to be part of the Authentication process.
