Anyconnect localization/customization when using radius_server_challenge with DAP
mjuch
Level 2
Level 2
Hello everyone, has anyone already dealt with the localization of Anyconnect in conjunction with DAP? We use [radius_server_challenge] and get the following text in Anyconnect: “Enter a passcode or select one of the following options” etc.
In the Windows DAP I found .pak files with the text, but I can’t find anything in the Linux DAP. Anyone have a tip?
br Mike
DuoPablo
Hi @demiju1 ,
The challenge text cannot be modified within the Windows or Linux Authentication Proxy packages. There are technical reasons for this design consideration, but a potential alternative is to see if you can move the application to use the Universal Prompt via SAML instead of RADIUS. This gives the end user a more tailored login experience based on the 2FA device(s) they have enrolled and your organization’s Authentication Policy.
What are the differences between the various Cisco ASA configurations?
Hope this helps!
