Checkpoint VPN MFA authentication with Duo
harshiljethava
Hi team,
I am doing the poc of Duo MFA for checkpoint remote access vpn.
recently I have configured the setup as duo doc and even got the duo push on my mobile
after changing the ad credentials duo push was not working.
I have reverted the change but still I am not able to get duo push.
Thanks in advance.
DuoKristina
Hi there, we found an issue in versions 5.0.0 and 5.0.1 of the Duo Authentication Proxy that affected Check Point VPN logins. As version 5.0.0 of the proxy was the then-latest release when you posted your question here, I suspect you may have been running into this issue.
The good news is that we corrected the issue in Authentication Proxy 5.0.2, released Monday 9/28. Please give that updated version a try.
Duo, not DUO.
