Cisco ASA Push notification
dragan2
I have setup DUO proxy and local authentication on ASA. I have used this guide for setting local authentication:
https://help.duo.com/s/article/1144?language=en_US
It works but only with entering second password manually and I would like to setup push.
If i set DUO proxy as primary authentication it does not work.
If using local ASA authentication, can I setup push notification?
Dragan
Amy2
Level 5
Level 5
Hi Dragan,
Edit: The reason automatic push does not work in this case is because whenever the ASA is set up with both primary and secondary authentication servers, the user must provide an explicit input to satisfy the secondary auth requirement. Unfortunately, there is no way to use the local users database on the ASA and also have autopush.
