Cisco DUO integration with Cisco Anyconnect VPN running on ASA
Hi!
I am planning to integrate with Cisco DUO with Anyconnect VPN running on ASA. I am planning to create local users on ASA to create Anyconnect profile for primary authentication. I am also planning to integrate Cisco DUO for MFA with the Anyconnect. I want to to know if DUO can work in this case as there is not separate Active Directory/RADIUS server available for primary authentication since users will be locally created on ASA. Please share your thoughts on how I can integrate DUO with anyconnect.
DuoKristina
Hi @AmeyaThorat. It’s a good idea to read through the documentation and FAQs and check the Knowledge Base for information before beginning your Duo deployment.
Take a look at Can I use Duo to protect ASA local account logins?
Duo, not DUO.
DuoKristina
Duo, not DUO.
