Cisco Duo SSO subdomain query
Vishal6
Level 3
Level 3
Hi All,
As I saw in video regarding SSO features with cisco duo we require subdomain to access that SSO portal. Basically I need to know what will be the target pointer for that subdomain.
jamieis
Hi @Vishal,
I’m Jamie, an engineer on our SSO team!
Duo SSO offers a landing page that your users can use to access Duo SSO protected applications or other bookmarks you’d like to share. This portal is called Duo Central.
You don’t need a custom subdomain to use Duo Central, you’ll be provided an automatically generated URL if not. If you would like to use a custom subdomain though, you can follow the steps here to add on. Custom subdomains will always be in the format of example.login.duosecurity.com where example is the custom subdomain.
Vishal6
Level 3
Level 3
Hi Jamie,
Can I use my subdomain like SSO.example.com instead of login.example.duosecurity.com
Hi @Vishal,
Duo SSO only supports custom subdomains that are prepended to login.duosecurity.com but a lot of DNS providers allow you to set up custom forwards where you could send sso.example.com to redirect to login.example.duosecurity.com
Hi Jamie,
Basically i want to integrate Custom application using Websdk using java codes downloaded from duo client libaries. Need to provide clientId, clientSecret, api.host, and redirect.uri. Can you help me where i can get this details.
