06-13-2025 01:03 PM
Since FortiGate will no longer support SSL VPN, we are going to switch to using Client IPsec VPN. However, I wonder if we can still use Cisco Duo for MFA, as there is no application or tutorial available for this purpose.
06-14-2025 08:29 AM
Hello @hossam-adel
If moving away from SSL VPN, Fortinet’s built-in MFA tokens are natively supported for IPsec.
Othet thing, VPN SSL not supported started version 7.6.3...is a feature train yet. You want to swirth to IPSEC right now ?
06-14-2025 09:25 AM
Yes, we need to switch to IPsec right now, and Fortinet's built-in MFA isn't an option since we already have about 50 seats with Cisco Duo.
06-17-2025 06:17 AM
Yes, you can keep using Duo via RADIUS, LDAP, or SAML with Fortigate IPSec Client VPN.
From our review so far, it looks like the steps to create the Duo RADIUS server or the Duo SAML config on the Fortigate are still very similar to what we have documented in...
SAML: https://duo.com/docs/sso-fortinet-fortigate
RADIUS: https://duo.com/docs/fortinet
With the difference being that instead of editing an SSL VPN configuration you instead would be editing an IPSec VPN config to add Duo.
https://docs.fortinet.com/document/fortigate/7.6.0/ssl-vpn-to-ipsec-vpn-migration/446639
