Compatibility with Graphon Go-Global?
jgonya
Is Go-Global one of the supported applications to protect?
DuoPablo
Hi @jgonya ,
Go-Global is currently not a named integration, but if it support RADIUS, LDAP, or SAML then it can likely be protected by Duo using our generic integration methods.
You may submit this Feature Request via your Duo Account Executive, Customer Success Manager (if applicable), or our Support Team.
Hope this helps!
