Configure an Application in Duo Network Gateway
chris.m.schmidt
I am using Duo Network Gateway with an on-premises web application, Looker, that sends queries to a Redshift database. However, queries that take longer than 60 seconds are being cancelled. Is there a way to change the web application configuration settings (e.g., proxy_read_timeout) so that queries running for longer than 60 seconds do not get cancelled? Here is an sample NGINX configuration with the settings I would like to replicate: https://docs.looker.com/setup-and-management/on-prem-install/sample-nginx-config
0 Replies 0
