Deprecated SSL and Weak Ciphers
sd_dbray
A vulnerability scan of a Linux server running the LDAP Proxy duoauthproxy will reveal the following vulnerabilities:
SSL/TLS: Deprecated SSLv2 and SSLv3 Protocol Detection
In addition to TLSv1.0+ the service is also providing the deprecated SSLv3 protocol and supports one or more ciphers. Those supported ciphers can be found in the ‘SSL/TLS: Report Weak and Supported Ciphers’ (OID: 1.3.6.1.4.1.25623.1.0.802067) NVT.
SSL/TLS: Report Weak Cipher Suites
’Weak’ cipher suites accepted by this service via the TLSv1.2 protocol:
TLS_RSA_WITH_RC4_128_MD5
TLS_RSA_WITH_RC4_128_SHA
TLS_RSA_WITH_SEED_CBC_SHA
After checking over the configs and documentation, I am not finding the necessary settings to remove SSLV2/3 nor update the weak ciphers.
Is there and advanced setting or something I am missing?
11 Replies 11
mkorovesisduo
Level 4
Level 4
Hi sd_dbray. At present, there is no option for customers to edit SSL/TLS configuration (both protocol versions and ciphersuites) in the Authentication Proxy.
We do plan to restrict SSL/TLS versions allowed by the proxy, but that is still a work-in-progress.
Thanks for the update, appreciate it.
Are there any updates on restricting SSL/TLS versions allowed by the proxy, our auditors are finding issues on some of our servers and want us to get these corrected.
@sjj2,
Please contact Duo Support to discuss your auditor findings; we’d like more information.
Duo, not DUO.
I’m having the same issues with our security department’s scans flagging for weak ciphers. We’ve reached out to DUO support, but we keep getting replies with solutions to harden a web server (from links to commonly found articles via a Google search). Is there a particular subject I should put in a ticket to get my concerns/issues to the correct individual/team? Also, is there a time frame for when this will be addressed? Thanks much.
Any update from duo support? I installed the latest version for duoproxy but the weak ciphers are still there. I would like to disable sslv3 and TLSv1.0 as well
[root@DMZ-LB02 webvis]# nmap --script ssl-enum-ciphers -p 636 192.168.xxx.xxx
Starting Nmap 6.40 ( http://nmap.org ) at 2019-01-02 17:06 +08
Nmap scan report for xxxxxx (192.168.xxx.xxxx)
Host is up (0.00038s latency).
PORT STATE SERVICE
636/tcp open ldapssl
| ssl-enum-ciphers:
| SSLv3:
| ciphers:
| TLS_ECDHE_RSA_WITH_3DES_EDE_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_ECDHE_RSA_WITH_RC4_128_SHA - strong
| TLS_RSA_WITH_3DES_EDE_CBC_SHA - strong
| TLS_RSA_WITH_AES_128_CBC_SHA - strong
| TLS_RSA_WITH_AES_256_CBC_SHA - strong
| TLS_RSA_WITH_CAMELLIA_128_CBC_SHA - strong
| TLS_RSA_WITH_CAMELLIA_256_CBC_SHA - strong
| TLS_RSA_WITH_IDEA_CBC_SHA - weak
| TLS_RSA_WITH_RC4_128_MD5 - strong
| TLS_RSA_WITH_RC4_128_SHA - strong
| TLS_RSA_WITH_SEED_CBC_SHA - strong
| compressors:
| NULL
| TLSv1.0:
| ciphers:
| compressors:
| NULL
| TLSv1.1:
| ciphers:
| compressors:
| NULL
| TLSv1.2:
| ciphers:
| TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 - strong
| TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384 - strong
| TLS_RSA_WITH_AES_128_CBC_SHA256 - strong
| TLS_RSA_WITH_AES_128_GCM_SHA256 - strong
| TLS_RSA_WITH_AES_256_CBC_SHA256 - strong
| TLS_RSA_WITH_AES_256_GCM_SHA384 - strong
| compressors:
| NULL
|_ least strength: weak
I managed to implement a temporary solution. I simply bind it to localhost and have haproxy sitting infront of it to handle SSL/TLS configuration (both protocol versions and ciphersuites)
If you are running more than one instance of duoproxy or multiple listening IP on one instance of a single server, simply bind each of them to 127.0.0.1, 127.0.0.2, 127.0.0.3.
This solution will keep the vulnerability scanning tool happy. Hopefully it helps. If you need more help i can provide the configuration of haproxy and duoproxy
I see the proxy docs now say you can control the ciphers and TLS/SSL version however I’m not able to get a clean scan after adjusting those settings. Is it still the case that those aren’t user-tunable?
@Cooper,
Did you update your Authentication Proxy version to 2.12.0? Did you cycle the proxy service after editing the .cfg file?
Duo, not DUO.
I thought I was at at least 2.12.0 but when I checked I wasn’t. I’m now trying to remember how I installed the proxy as non-root so that I can upgrade.
@Cooper
Thank you very much update. I downloaded the latest, updated the config, re-ran my OpenVAS scans, and no more vulnerabilities detected.
Thanks!
