Desktop Authentication compatible with RAS VPN / Authentication Proxy?
layer9de
Dear all,
we are using Cisco Duo as MFA solution for Microsoft RAS VPN with Duo Authentication Proxy. We are now looking into Duo Desktop Authentication as additional authentication method:
https://duo.com/blog/introducing-duo-desktop-authentication
The documentation however states the following as requirement:
- Supported Duo applications which feature the Duo Universal Promp
The Microsoft RAS VPN / Duo Authentication Proxy however do not support the Universal Prompt nor any other Prompt at all. Does anyone know whether Duo Desktop authentication can be used as authentication method in this case?
Michael
DuoKristina
No, Duo Desktop Authentication, which requires Duo Universal Prompt, cannot be used with RAS VPN configurations that do not show the Duo Universal Prompt.
ETA: for most remote access/VPN solutions we'd suggest using Duo SSO for SAML authentication. When a VPN is federated with Duo SSO then VPN logins go through the Duo Universal Prompt and Duo Desktop authentication is an option.
It is my recollection that Microsoft RRAS authentication support is limited and does not offer SAML as an option, so this may not be possible for you.
Duo, not DUO.
DuoKristina
Duo, not DUO.
Thank you Kristina, I actually thought that with manual enrollment for Duo Desktop it was possible to register Duo Desktop as additonal authentication method. Since it is not possible for applications without the Duo Universal Prompt we're sticking with Duo Mobile for VPN/RAS authentications then.
Best Regards
Michael
