Duo Auth Proxy with seperate Radius servers
JG1978
I have 1 server running the DUO auth proxy for our Radius authentication. It works today with 1 ASA pointed at it for VPN and then it points to our Primary Radius Servers.
I now have a 2nd set of Radius servers that handle a specific application that runs on a different firewall, how can I add 2nd set of Radius servers on same Proxy?
This is not a backup solution but separate instance. If I add a new radius_client2 will this allow separate instance to work independent of current config?
[radius_client_2]
Host=x.x.x.x
Secret=xxxxx
And then under the ASA part:
[radius_server_2]
Ikey=xxxxxxx
Skey=xxxxxxx
Api=xxxxxxxxx
Radius_ip_1=ASA IP
Radius_secret=xxxxxx
Client=radius_client_2
DuoKristina
Yes, you have that exactly right.
Duo, not DUO.
DuoKristina
Duo, not DUO.
JG1978
Great, thanks for confirming!
