Duo for Azure/O365 and RDP
ulisses
We’re looking to implement Duo both for Azure/O365 and local logons. We started going through the steps for implementing DAG, but something feels like it is not the best solution for this scenario.
Should we be looking into Azure Conditional Access and Duo for RDP instead?
Thanks!
alvinabraham
for Azure and O365, if you are using ADFS you can install the Duo MFA Adapter and set your Access Policy to use DUO MFA.
If you dont have ADFS they DAG is similiar to ADFS.
cbryan2
I think we were doing the exact same thing as you. Are you using Azure AD as your primary or are you using ADFS and using on-prem AD for your primary authentication source?
