Duo for SSH, unable to get basic success
clearwatersam
I am testing Duo for SSH on a test server. Ubuntu 22.04 fresh install just for testing. This is on Login_duo not the PAM module. Following these instructions:
Duo Unix - Two-Factor Authentication for SSH (login_duo) | Duo Security
I have tried from packages and from source just for fun. Same issue. I am not trying anything fancy in the config for now, nothing but ikey,skey,host,pushinfo,autopush.
Testing with /usr/sbin/login_duo -d just shows an error about incorrect ikey OR secret key. I have gone through the instructions to this point more than once, triple checked the keys for my unix application. I don't see any errors in the process and am at a loss that I am getting stomped with such a straightforward error.
Is there any way an incorrect ikey error could mean something entirely different? It is such a stupid basic thing I can't seem to find any other threads with the same issue.
DuoKristina
Our API error responses are pretty specific, so if you are getting the "40103 Invalid signature in request credentials" response checking the ikey/skey is indeed what usually fixes it. Is it possible you have hidden characters in your login_duo.conf file at the end of the lines?
Duo, not DUO.
