DUO MFA on Checkpoint Remote Access/Mobile Access VPN
nischit123aryal
This post will help those who want to integrate DUO MFA on Checkpoint Remote Access/Mobile Access VPN.
Step 1 - Follow this documentation shared by DUO for Checkpoint Mobile Access Two-Factor Authentication for Check Point Mobile Access | Duo Security
Apart from the above steps, it required additional configuration on Checkpoint for DUO MFA to work
Step 2 - Follow the steps below
  • Go to Manage and Settings followed by Blades and then Click “Configure in SmartDashboard”. The legacy SmartDashboard client will open.
  • Click on the “User” icon in the Object Explorer in the bottom left. Then right-click “External User Profiles” and select “New External User Profile > Match all users”.
  • Select Authentication on the left pane. Change the Authentication Scheme to RADIUS and select the RADIUS server object we created for DUOMFA.
  • Click “OK” and save your changes. Then close the SmartDashboard window.
jamesmay62361
I have successfully completed the integration of duo into my checkpoint infrastructure. However, I am trying to locate a better user interface with checkpoint vpn client. For example the GUI interface presented when using duo to authenticate a webpage. You get authentication options push, sms, phone call. While in checkpoint vpn client, you have type the user password followed by a comma then notification type. This is far from an optimal process, and was looking for another interface if possible here?
