Duo OpenVPN on Untangle
adub1
Just wondering if anyone has used DUO to secure the OpenVPN portion of the Untangle Firewall?
6 Replies 6
adub1
just finished implementation…it was super easy!
adub: can you please share more instructions?
adub1
My only problem is when openvpn prompts for the the password, I do have to specify a username. The docs state that field is ignored and pulled from the CN in the certificate, however the ok button stays greyed out until I type in my username… any ideas?
adub1
I just followed the directions here… Two-Factor Authentication for OpenVPN | Duo Security
I’m using openVPN on an Untangle firewall. The implementation even survived an upgrade, which is not guaranteed…
ML2021
Sorry to resuscitate an old post. how did this fare through Untangle updates? Thanks for any info.
I believe I was on V14x at the time of installation…It survived all updates to current which is 16.2!
